Is there somewhere I can find out more about what aspects of simulated robot motion and control the UR Sim offline simulator takes into account?
I assume it tries to run the program at the native controller timing rate of the corresponding robot.
Does it simulate controller dynamics like the effects of servoJ gain/lookahead settings? What about physical dynamics? (I doubt it, but I’m curious)
I’m trying to debug some motion problems with some external control software, and some overshoot behaviors I saw on the physical robot occur the same when using UR Sim.
I didn’t really expect this, so I’m trying to understand more about what to expect for the simulator’s response to external joint position commands (we’re supplying them over RTDE and using servoJ in a loop to move the robot).
Is there a technical user manual for UR Sim that describes this in some detail?
I’m using the ROS2 driver and it seems like URSim reports joint torques (efforts) roughly consistent with gravity statics on the arm if gravity were set to 0.1 gee. Doesn’t seem to take payload into account. Does it also do dynamic torques? Really interesting tool.
