We want to move the robot via 4 waypoints. When we try to send this as a script via primary interface as below, the robot is only moving to the last waypoint
“def move():\r\n” +
“global PoseForMoveK = p[” + (digitalOutOnpose.Xm).ToString() + ", " + (digitalOutOnpose.Ym).ToString() + ", " + (digitalOutOnpose.Zm).ToString() + ", " + (digitalOutOnpose.RxRad).ToString() + ", " + (digitalOutOnpose.RyRad).ToString() + ", " + (digitalOutOnpose.RzRad).ToString() + “]\r\n” +
“global PoseForMoveL = p[” + (InitialPose.Xm).ToString() + “,” + (InitialPose.Ym).ToString() + “,” + (InitialPose.Zm).ToString() + “,” + (InitialPose.RxRad).ToString() + “,” + (InitialPose.RyRad).ToString() + “,” + (InitialPose.RzRad).ToString() + “]\r\n” +
"movel( PoseForMoveK, a= " + 50.ToString() + “, v= " + spraySpeed.ToString() + " , t=0, r=0)\r\n” +
"movel( PoseForMoveL, a= " + 50.ToString() + “, v= " + spraySpeed.ToString() + " , t=0, r=0)\r\n” +
“end” + “\r\n”;
What we expect is that the robot will move to first point, stop there will go to the second point and continue till the last movel command. What are we missing here?
