UDP socket sensor
Hi there !
I got a new sensor, ATI_NET_FT, and it works with UDP sockets. When I create a socket communication with my PC in Eclipse, it works just fine. But when I tried to communicate my robot to the sensor via UDP in a URCap, it doesn’t work.
The UR Robots only works with TCP/IP? Is there a way to use UDP communication?
Thanks for your time
Hi @anon23279734,
How were you trying to implement it exactly? UDP communication is definitely possible through a Python daemon. You could then pass the data into Polyscope using XMLRPC.
https://wiki.python.org/moin/UdpCommunication
https://www.universal-robots.com/how-tos-and-faqs/how-to/ur-how-tos/xml-rpc-communication-16326/
