Set JFileChooser path to resource
Hi all,
I have a problem when i want to set the current directory to a JFileChooser pointing to my resource. (Program Node Contribution)
I’ve done this, but it doesn’t work:
JFileChooserObj.setCurrentDirectory(this.getClass().getResources("/"));
How can i take the absolute path? or another way to do it?
Thanks!!
Hello @anon89006500,
There was a similar issue posted a while back, you can check it out here. Let me know if that helps!
the code you are suggesting worked fine to Read, @inu, but Im having troubles writing to that file.
could you share a snip of code to writing o an existent .txt file on my resource folder?
