Hello.
I´ve carry out the payload assistant, my actually payload shoud be round about 2kg but the assisxtant shows 0 also the COG shows me 0. Need some help. (actually software 5.12.2, robot UR5e)
thanks in advance
Mathias
Hello.
thanks in advance
Mathias
Hi Mathias,
Have you tried to measure payload from the robot?
Tool Configuration: TCP, orientation, payload & center of gravity - YouTube
If not, try measuring according to this tutorial.
Hello giorgigedaminski,
i have done that, we have two ur5e in our company, i did the payload measure with the other robot, no problems there.
Mathias
knwo i have tried that:
Sounds like a faulty force/torque sensor. ![]()
You can test it by making a new program with an assignment, where you write the current force values to the variable each 0.1 second or something. Then you should be able to tell, if some of the values seem wrong.
Maybe a recalibration of the sensor can solve it, too. This can only be done at UR’s production facilities, though. You should contact a distributor.
Did you solve the issue? I’m having the sameone. I’m not able to solve this yet.
Did you try the test, which I suggested? Should give you a clear indication if the force/torque sensor is working correctly. ![]()
At the moment the Problem is not solved, we have send the torque sensor to UR.
They told us, they want to kalibrate the sensor new, to solve the problem.
Mathias
