Line palletizing
Hi all I have question to ask…how to skip part on palletizing for example i have 7 pcs part on my pallet if part no two not present how do i jump to part number three…thanks all
You can put your whole Palletize node in a loop node. Then repeat the loop as long as a variable is False.
In your pick up sequence, you make a check (If node) to see, if the robot has picked up the object succesfully. When it is picked up, you set the variable to True. :slight_smile:
Also, remember to set the variable to False before entering the Palletize node. :slight_smile:
