Hi all,
I’m using polyscope 3.5.3.
When I using the “get_tcp_force()”,
data = get_tcp_force()
how to I save the all output value(all time)?
Hi all,
Hello!
When you use “get_tcp_force()” you will get it as a Pose ( as p[X, Y, Z, rX, rY, rZ] ) . But if you call that variable as a regular list, so you can get each value by itself.
So to get the X, Y, Z, rX, rY and rZ values in their own int variables, you can use:
dataX = data[0] dataY = data[1] dataZ = data[2] datarX = data[3] datarY = data[4] datarZ = data[5]
Edit: Found the UR How-To also.
https://www.universal-robots.com/how-tos-and-faqs/how-to/ur-how-tos/read-a-single-coordinate-or-axis-rotation-15379/
