Steps to reproduce:
- Open the settings from the burger menu at the top right
- Select a tab that is normally disabled in Remote Control (e.g. Security → Secure Shell)
- Close settings and put robot in Remote Control
- Open the settings again
- Change settings in this tab (that is normally disabled in Remote Control)
Expected Behavior:
- This is not possible. You cannot open a disabled tab (e.g. Security → Secure Shell) in Remote Control
- Since you cannot open that tab, you cannot change its settings
Actual Behavior:
- We closed the settings with the Security → Secure Shell tab open
- We are still in this tab when we re-open the settings (now in remote control)
- We can change parameters in this tab
Workaround Suggestion:
Robot Serial Number:
Affected Version(s):
- Polyscope 5.21.0
