Hello, my Name is Tim. I am attending Purdue University Indianapolis and I am currently on a senior Design team involving a UR5e Cobot. I am developing a URCap and I am having trouble getting the UI to update accordingly and I think I am having trouble getting this daemon server starting correctly. The goal of this URCap is to:
Create live camera feed using the usb camera plugged into the controller.
Detect 2D shapes or drawings shown to the camera
With the shapes it detects, draw with an expo marker (and an adjusted TCP to the tip of the expo marker) the shapes it sees on a vertically mounted white board.
The daemon should return movements that the Cobot can move using moveL or move J. (There is some backend calculations needing to take place to achieve this.
What I have achieve so far is a working python file. I was able to pip install numpy, and opencv using python 2.7. This is the version of python currently on the controller.
I need help making sure my code is correct and if there is any feedback or logic errors you guys see, this would be a big help. Thank you!
(As I am a new user, I cannot do file uploads. So here is some raw code)
package com.ECET.CameraDrawApp.impl;
import java.net.MalformedURLException;
import java.net.URL;
import com.ur.urcap.api.contribution.DaemonContribution;
import com.ur.urcap.api.contribution.DaemonService;
public class CameraDaemonService implements DaemonService{
private DaemonContribution daemonContribution;
@Override
public void init(DaemonContribution daemon) {
this.daemonContribution = daemon;
try {
// Ensure the daemon is installed correctly
daemonContribution.installResource(new URL("file:com/ECET/CameraDrawingApp/impl/daemon/"));
} catch (MalformedURLException e) {
System.err.println("Malformed URL in daemon service: " + e.getMessage());
} catch (Exception e) {
System.err.println("Failed to install daemon resource: " + e.getMessage());
@Override
public URL getExecutable() {
try {
return new URL("file:com/ECET/CameraDrawingApp/impl/daemon/camera-daemon.py");
System.err.println("Could not load the daemon executable: " + e.getMessage());
return null;
public DaemonContribution getDaemon() {
return daemonContribution;
import java.awt.image.BufferedImage;
import java.io.ByteArrayInputStream;
import java.util.ArrayList;
import java.util.List;
import java.util.concurrent.Executors;
import java.util.concurrent.ScheduledExecutorService;
import java.util.concurrent.TimeUnit;
import javax.imageio.ImageIO;
import org.apache.commons.codec.binary.Base64;
import org.apache.xmlrpc.XmlRpcException;
import org.apache.xmlrpc.client.XmlRpcClient;
import org.apache.xmlrpc.client.XmlRpcClientConfigImpl;
public class XmlRpcCameraDrawingAppDaemonInterface {
static final String SERVER_URL = “http://127.0.0.1:40405/RPC2”;
private final XmlRpcClient client;
private final ScheduledExecutorService executorService = Executors.newScheduledThreadPool(1);
private boolean daemonReachable;
public XmlRpcCameraDrawingAppDaemonInterface() throws Exception {
XmlRpcClientConfigImpl config = new XmlRpcClientConfigImpl();
config.setServerURL(new URL(SERVER_URL));
client = new XmlRpcClient();
client.setConfig(config);
startDaemonMonitor();
private void startDaemonMonitor() {
executorService.scheduleAtFixedRate(() -> {
try {
daemonReachable = ping();
daemonReachable = false;
}, 0, 2, TimeUnit.SECONDS);
* Checks if the daemon is reachable.
* @return True if daemon is reachable, false otherwise.
public boolean isDaemonReachable() {
return daemonReachable;
* Sends a ping request to the daemon.
* @return True if daemon responds, false otherwise.
public boolean ping() {
try {
return (boolean) client.execute("ping", new Object[]{});
} catch (XmlRpcException e) {
return false;
* Retrieves an image from the camera as a BufferedImage.
* The image is received as a Base64-encoded string and converted back to BufferedImage.
public BufferedImage getCameraFrame() throws XmlRpcException {
try {
Object response = client.execute("GetImage", new ArrayList<>());
if (response instanceof String) {
byte[] imageBytes = Base64.decodeBase64((String) response);
return ImageIO.read(new ByteArrayInputStream(imageBytes));
} else {
throw new XmlRpcException("Invalid response type from daemon. Expected Base64 string.");
throw new XmlRpcException("Error retrieving camera frame: " + e.getMessage());
* Retrieves detected shapes from the camera feed.
* The data is structured as a list of coordinate points.
public List<List<Double>> detectShapes() throws XmlRpcException {
try {
Object response = client.execute("detect_shapes", new ArrayList<>());
if (response instanceof Object[]) {
List<List<Double>> shapes = new ArrayList<>();
for (Object item : (Object[]) response) {
if (item instanceof List) {
List<?> rawList = (List<?>) item;
List<Double> shape = new ArrayList<>();
for (Object point : rawList) {
if (point instanceof Double) {
shape.add((Double) point);
} else {
throw new XmlRpcException("Invalid data type in shape coordinates.");
shapes.add(shape);
} else {
throw new XmlRpcException("Invalid shape data structure.");
return shapes;
} else {
throw new XmlRpcException("Invalid response type from daemon.");
throw new XmlRpcException("Error retrieving detected shapes: " + e.getMessage());
* Enables or disables auto-focus.
* @param enable True to enable auto-focus, False to disable.
public void setAutoFocus(boolean enable) throws XmlRpcException {
try {
List<Object> params = new ArrayList<>();
params.add(enable);
client.execute("setEnableAutoFocus", params);
throw new XmlRpcException("Error setting auto-focus: " + e.getMessage());
* Sets the focus level of the camera.
* @param value Focus level (0-100).
public void setFocusLevel(int value) throws XmlRpcException {
try {
params.add(value);
client.execute("setFocusValue", params);
throw new XmlRpcException("Error setting focus level: " + e.getMessage());
* Sets the exposure level of the camera.
* @param value Exposure level (0-100).
public void setExposureLevel(int value) throws XmlRpcException {
try {
params.add(value);
client.execute("setExposureValue", params);
throw new XmlRpcException("Error setting exposure level: " + e.getMessage());
public void stopMonitor() {
executorService.shutdown();
import javax.swing.SwingUtilities;
import com.ur.urcap.api.contribution.InstallationNodeContribution;
import com.ur.urcap.api.contribution.installation.InstallationAPIProvider;
import com.ur.urcap.api.domain.data.DataModel;
import com.ur.urcap.api.domain.script.ScriptWriter;
public class CameraDrawingAppInstallationNodeContribution implements InstallationNodeContribution {
// Constants for DataModel keys
private static final String DAEMON_RUNNING_KEY = "daemonRunning";
private static final String AUTO_FOCUS_KEY = "autoFocus";
private static final String FOCUS_LEVEL_KEY = "focusLevel";
private static final String EXPOSURE_LEVEL_KEY = "exposureLevel";
// Dependencies
private final CameraDrawingAppInstallationNodeView view;
private final DataModel model;
private final CameraDaemonService daemonService;
private final XmlRpcCameraDrawingAppDaemonInterface daemonInterface;
// Executor for UI updates
private ScheduledExecutorService executorService;
public CameraDrawingAppInstallationNodeContribution(InstallationAPIProvider apiProvider,
CameraDrawingAppInstallationNodeView view,
DataModel model,
CameraDaemonService daemonService,
XmlRpcCameraDrawingAppDaemonInterface daemonInterface) {
this.view = view;
this.model = model;
this.daemonService = daemonService;
this.daemonInterface = daemonInterface;
this.executorService = Executors.newScheduledThreadPool(1);
initializeDataModel();
applyDaemonStatus();
private void initializeDataModel() {
if (!model.isSet(DAEMON_RUNNING_KEY)) model.set(DAEMON_RUNNING_KEY, false);
if (!model.isSet(AUTO_FOCUS_KEY)) model.set(AUTO_FOCUS_KEY, true);
if (!model.isSet(FOCUS_LEVEL_KEY)) model.set(FOCUS_LEVEL_KEY, 50);
if (!model.isSet(EXPOSURE_LEVEL_KEY)) model.set(EXPOSURE_LEVEL_KEY, 50);
@Override
public void openView() {
updateUI();
restartExecutorService();
@Override
public void closeView() {
shutdownExecutorService();
@Override
public void generateScript(ScriptWriter writer) {
writer.assign("camera", "rpc_factory(\"xmlrpc\", \" http://127.0.0.1:40405/RPC2\")");
writer.appendLine("if camera == None:");
writer.appendLine(" popup(\"Error: Unable to establish XML-RPC connection.\", \"Error\", False, True, False)");
writer.appendLine(" halt");
writer.appendLine("if camera.ping():");
writer.appendLine(" textmsg(\"Camera Daemon Connected\")");
writer.appendLine("else:");
writer.appendLine(" popup(\"Camera Daemon Unreachable\", \"Error\", False, True, False)");
public void onStartCameraPressed() {
model.set(DAEMON_RUNNING_KEY, true);
updateUI();
public void onStopCameraPressed() {
updateUI();
public void toggleAutoFocus() {
boolean autoFocus = model.get(AUTO_FOCUS_KEY, true);
model.set(AUTO_FOCUS_KEY, !autoFocus);
updateUI();
executeAsync(() -> {
try {
daemonInterface.setAutoFocus(!autoFocus);
logError("Failed to toggle auto-focus", e);
public void adjustFocus(int amount) {
int newFocus = clampValue(model.get(FOCUS_LEVEL_KEY, 50) + amount, 0, 100);
model.set(FOCUS_LEVEL_KEY, newFocus);
updateUI();
try {
daemonInterface.setFocusLevel(newFocus);
logError("Failed to adjust focus", e);
public void adjustExposure(int amount) {
int newExposure = clampValue(model.get(EXPOSURE_LEVEL_KEY, 50) + amount, 0, 100);
model.set(EXPOSURE_LEVEL_KEY, newExposure);
updateUI();
try {
daemonInterface.setExposureLevel(newExposure);
logError("Failed to adjust exposure", e);
private void applyDaemonStatus() {
boolean shouldRun = model.get(DAEMON_RUNNING_KEY, false);
try {
if (shouldRun) {
if (daemonInterface.ping()) {
daemonService.getDaemon().start();
} else {
logError("Daemon is unreachable, not starting.", null);
} else {
daemonService.getDaemon().stop();
logError("Failed to manage daemon status", e);
private void updateUI() {
boolean isRunning = model.get(DAEMON_RUNNING_KEY, false);
view.updateCameraStatus(isRunning ? "Camera Running" : "Camera Offline");
view.setStartButtonEnabled(!isRunning);
view.setStopButtonEnabled(isRunning);
private void restartExecutorService() {
if (executorService.isShutdown() || executorService.isTerminated()) {
executorService.scheduleAtFixedRate(() -> SwingUtilities.invokeLater(this::updateUI), 0, 2, TimeUnit.SECONDS);
private void shutdownExecutorService() {
if (executorService != null && !executorService.isShutdown()) {
private void executeAsync(Runnable task) {
new Thread(task).start();
private void logError(String message, Exception e) {
System.err.println(message + (e != null ? ": " + e.getMessage() : ""));
private int clampValue(int value, int min, int max) {
return Math.max(min, Math.min(max, value));
import java.awt.Color;
import java.awt.Component;
import java.awt.Dimension;
import java.awt.FlowLayout;
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
import javax.swing.BorderFactory;
import javax.swing.Box;
import javax.swing.BoxLayout;
import javax.swing.ImageIcon;
import javax.swing.JButton;
import javax.swing.JLabel;
import javax.swing.JPanel;
import com.ur.urcap.api.contribution.installation.swing.SwingInstallationNodeView;
public class CameraDrawingAppInstallationNodeView implements SwingInstallationNodeView{
private JButton startCameraButton;
private JButton stopCameraButton;
private JButton autoFocusButton;
private JButton increaseFocusButton;
private JButton decreaseFocusButton;
private JButton increaseExposureButton;
private JButton decreaseExposureButton;
private JLabel cameraStatusLabel;
private JLabel videoLabel;
private static final int VIDEO_WIDTH = 640;
private static final int VIDEO_HEIGHT = 480;
@Override
public void buildUI(JPanel panel, CameraDrawingAppInstallationNodeContribution contribution) {
panel.setLayout(new BoxLayout(panel, BoxLayout.Y_AXIS));
cameraStatusLabel = new JLabel("Status: Disconnected");
cameraStatusLabel.setAlignmentX(Component.LEFT_ALIGNMENT);
startCameraButton = new JButton("Start Camera");
stopCameraButton = new JButton("Stop Camera");
autoFocusButton = new JButton("Toggle Auto Focus");
increaseFocusButton = new JButton("Increase Focus");
decreaseFocusButton = new JButton("Decrease Focus");
increaseExposureButton = new JButton("Increase Exposure");
decreaseExposureButton = new JButton("Decrease Exposure");
videoLabel = new JLabel("No Video Available");
videoLabel.setPreferredSize(new Dimension(VIDEO_WIDTH, VIDEO_HEIGHT));
videoLabel.setMaximumSize(videoLabel.getPreferredSize());
videoLabel.setBorder(BorderFactory.createLineBorder(Color.BLACK));
startCameraButton.addActionListener(new ActionListener() {
@Override
public void actionPerformed(ActionEvent e) {
contribution.onStartCameraPressed();
stopCameraButton.addActionListener(new ActionListener() {
@Override
contribution.onStopCameraPressed();
autoFocusButton.addActionListener(new ActionListener() {
@Override
contribution.toggleAutoFocus();
increaseFocusButton.addActionListener(new ActionListener() {
@Override
contribution.adjustFocus(1);
decreaseFocusButton.addActionListener(new ActionListener() {
@Override
contribution.adjustFocus(-1);
increaseExposureButton.addActionListener(new ActionListener() {
@Override
contribution.adjustExposure(1);
decreaseExposureButton.addActionListener(new ActionListener() {
@Override
contribution.adjustExposure(-1);
// Layout Setup
panel.add(cameraStatusLabel);
panel.add(Box.createRigidArea(new Dimension(0, 10)));
panel.add(videoLabel);
JPanel buttonPanel = new JPanel();
buttonPanel.setLayout(new FlowLayout(FlowLayout.LEFT));
buttonPanel.add(startCameraButton);
buttonPanel.add(stopCameraButton);
buttonPanel.add(autoFocusButton);
panel.add(buttonPanel);
JPanel controlPanel = new JPanel();
controlPanel.setLayout(new FlowLayout(FlowLayout.LEFT));
controlPanel.add(increaseFocusButton);
controlPanel.add(decreaseFocusButton);
controlPanel.add(increaseExposureButton);
controlPanel.add(decreaseExposureButton);
panel.add(controlPanel);
public void updateCameraStatus(String status) {
cameraStatusLabel.setText(status);
public void updateVideoFeed(ImageIcon image) {
videoLabel.setIcon(image);
public void setStartButtonEnabled(boolean enabled) {
startCameraButton.setEnabled(enabled);
public void setStopButtonEnabled(boolean enabled) {
stopCameraButton.setEnabled(enabled);
Program node for drawing. In the program tree, it will just show the camera feed. At run, time if will popup and try to confirm the user has a drawing present.
import java.util.Timer;
import java.util.TimerTask;
import com.ur.urcap.api.contribution.ProgramNodeContribution;
import com.ur.urcap.api.contribution.program.ProgramAPIProvider;
public class CameraDrawingAppProgramNodeContribution implements ProgramNodeContribution{
@SuppressWarnings("unused")
private final ProgramAPIProvider apiProvider;
private final CameraDrawingAppProgramNodeView view;
private Timer uiTimer;
public CameraDrawingAppProgramNodeContribution(ProgramAPIProvider apiProvider,
CameraDrawingAppProgramNodeView view,
DataModel model,
this.apiProvider = apiProvider;
this.view = view;
this.model = model;
@Override
if (uiTimer != null) {
uiTimer.cancel(); // Ensure no existing timer is running
uiTimer = new Timer(true);
uiTimer.scheduleAtFixedRate(new TimerTask() {
@Override
public void run() {
SwingUtilities.invokeLater(CameraDrawingAppProgramNodeContribution.this::updateUI);
}, 0, 1000); // Update every 1 second
@Override
uiTimer.cancel();
uiTimer = null;
@Override
public String getTitle() {
return "Camera Drawing";
@Override
public boolean isDefined() {
// TODO Auto-generated method stub
return true;
try {
BufferedImage frame = daemonInterface.getCameraFrame(); // Now returns BufferedImage
if (frame != null) {
SwingUtilities.invokeLater(() -> view.updateVideoFeed(frame));
System.err.println("Error fetching video frame: " + e.getMessage());
@Override
writer.assign("cam", "rpc_factory(\"xmlrpc\", \"" + XmlRpcCameraDrawingAppDaemonInterface.SERVER_URL + "\")");
writer.appendLine("if cam.ping():");
writer.appendLine("shapes = cam.detect_shapes()");
writer.appendLine("if str_len(to_str(shapes)) == 0 or shapes == None:");
writer.appendLine(" popup(\"No shapes detected!\", \"Error\", False, True, False)");
writer.appendLine("board_origin = p[0.5, 0.2, 0.1, 0, 3.1415, 0]");
writer.appendLine("approach_height = 0.05");
writer.appendLine("drawing_speed = 0.1");
writer.appendLine("move_speed = 0.25");
writer.appendLine("shape_idx = 0");
writer.appendLine("while shape_idx < length(shapes):");
writer.appendLine(" shape = shapes[shape_idx]");
writer.appendLine(" if length(shape) > 0:");
writer.appendLine(" pt_idx = 0");
writer.appendLine(" pt0 = shape[pt_idx]");
writer.appendLine(" target0 = pose_trans(board_origin, p[pt0[0]*0.0254, pt0[1]*0.0254, 0, 0, 0, 0])");
writer.appendLine(" movej(pose_trans(target0, p[0,0,approach_height,0,0,0]), a=1.2, v=move_speed)");
writer.appendLine(" movel(target0, a=0.5, v=drawing_speed)");
writer.appendLine(" pt_idx = pt_idx + 1");
writer.appendLine(" while pt_idx < length(shape):");
writer.appendLine(" pt = shape[pt_idx]");
writer.appendLine(" target_pt = pose_trans(board_origin, p[pt[0]*0.0254, pt[1]*0.0254, 0, 0, 0, 0])");
writer.appendLine(" movel(target_pt, a=0.5, v=drawing_speed)");
writer.appendLine(" end");
writer.appendLine(" shape_idx = shape_idx + 1");
writer.appendLine("end");
writer.appendLine("popup(\"Shape drawing completed!\", \"Done\", False, False, False)");
import com.ur.urcap.api.contribution.ContributionProvider;
import com.ur.urcap.api.contribution.program.swing.SwingProgramNodeView;
public class CameraDrawingAppProgramNodeView implements SwingProgramNodeView{
@Override
public void buildUI(JPanel panel, ContributionProvider<CameraDrawingAppProgramNodeContribution> provider) {
videoLabel = new JLabel("No Video Feed");
* Updates the video feed with a BufferedImage.
* @param image The BufferedImage to display.
public void updateVideoFeed(BufferedImage image) {
if (image != null) {
videoLabel.setIcon(new ImageIcon(image));
} else {
videoLabel.setText("No Video Available");
If this is too much to go into detail in this discussion, I have the GitHub link below.
