C50A6 Alarm Code
Hello! I replaced both power supplies this morning due to a C72A2 Alarm code. Now when I power up I am met with a new error of C50A6 I adjusted the voltage on the power supply and even checked the output amount and it doesn’t reach 56V i was curious if there’s something else I should be checking.
Thank you!
Incase anyone else has this problem:
Our fix was leveling the voltage between the two supplies and replacing the Safety Board.
