urx.urrobot.RobotException: Goal not reached but no program has been running for 5 seconds. dist is 0.049986025435063766, threshold is 0.039996845948998494, target is [-0.14482926 -0.30244145 0.50537851 0.26114389 3.1118598 -0.02745581], current pose is [-0.14483246457180995, -0.30244258900071636, 0.45539258969714447, 0.26125436683863307, 3.111797943232082, -0.027527518798631107]
Hello @anon62377786 ,
can you provide further intel about your setup and program used? From the information you have provided it is not quite clear to me what you are trying to do.
I use Python urx to control ur5e robot, but there will be the error I mentioned above. Is it a version problem? Do you know why? thank you!
This is my program
import urx
import logging
if name == “main”:
logging.basicConfig(level=logging.WARN)
rob = urx.Robot("172.16.17.6")
#rob = urx.Robot("localhost")
# rob.set_tcp((0,0,0,0,0,0))
rob.set_tcp((-0.145,-0.302,0.055,0.261,3.112,-0.027))
rob.set_payload(0.5, (0,0,0))
try:
l = 0.05
v = 0.05
a = 0.3
pose = rob.getl()
print("robot tcp is at: ", pose)
print("absolute move in base coordinate ")
pose[2] += l
rob.movel(pose, acc=a, vel=v)
print("relative move in base coordinate ")
rob.translate((0, 0, -l), acc=a, vel=v)
print("relative move back and forth in tool coordinate")
rob.translate_tool((0, 0, -l), acc=a, vel=v)
rob.translate_tool((0, 0, l), acc=a, vel=v)
finally:
rob.close()
