Strange timestamp on LabelMessage from Primary Interface
Output of primary interface
(1111416000, 'Key code 0, arg 0, title PROGRAM_XXX_STARTED, message unnamed')
(1111432000, 'Request value ID 4, type 2,asdfasdfasdf')
(18446744073709551615L, ('4:', "var_1\xe2\x89\x94'asdfasdfasdf'"))
(18446744073709551615L, ('6:', 'Waypoint_2'))
(18446744073709551615L, ('3:', 'Waypoint_1'))
(1118456000, 'Request value ID 5, type 2,asdfasdfasdf')
(1125224000, 'Request value ID 6, type 2,asdfasdfasdf')
(1137760000, 'Request value ID 7, type 2,asdfasdfasdf')
(1174280000, 'Request value ID 8, type 2,asdfasdfasdf')
(1262216000, 'Request value ID 9, type 2,asdfasdfasdf')
(1398752000, 'Key code 0, arg 0, title PROGRAM_XXX_STOPPED, message unnamed')
the timestamp I get on Label message is strange (value is way too high). The other messages look reasonable. I use the same function to decode message header for other types of messages, but I get these differing results. At the moment I am testing it in virtual machine. I still have to confirm if it looks the same on the robot.
Could someone confirm or deny these? Thanks!
Real robot does the same thing.
EDIT: Timestamp should be uint64_t, but it looks like it is int64 equal to -1.
Hi! I got this problem as you said, did you find any reasons?
I’m using SW 3.5.4.10845, UR5.
