Hi, I’m using the RTDE Interface node on node-red to convert the data collected through port 30001. The voltage value i’m getting for each joint is anomaly huge. Is there any way to fix this issue?
Is there any solution for this? I have the same large values. I have tried to convert from VECTOR6D to DOUBLE but no change.
