Shifting of GUI buttons and labels
Hi, I have trouble shifting my GUI buttons around. I encountered the following problem while trying to implement padding into the style of the button:
UR_button
Below is the code I use:
UR_button_code
Thank you!
Your issue right now is that the padding is affecting the text. If you want to put padding on the buttons then put the <input id = “disableButton” into a div component then add the padding to the div component.
Here is an example.
CSS:
The style for #Variable impacts the size of the inputTextField while the #Button shifts the inputTextField over 50px
Hi Roman,
Thank you so much, got it working!
