Can any one help me on this socket communication?
now I have programmed the movement in UR Polyscope, as next step I want to connect all movement together with Visual code in Python (main program); does any one know how to call these .urp program via socket communication?
Thank you in advance.
Why not use a socket and connect to the universal dashboard on port 29999.
Then call “load <yourprogram.urp>”
hi, thanks for replying.
I tried several times, but it does not work, don’t know why…
belows are my program
s.send(“load program.urp”)
Without brackets (<>)
Also in your program : where is s.bind ?
You should something like :
s.bind((HOST1, PORT1))
https://realpython.com/python-sockets/
hi, thanks a lot, this problem well solved.
the correct one is : s.send((“load program.urp”+“\n”).encode())
