NAME OF URCAP
Dialog Script URCap with using XML-RPC (second version)
Description of functionality:
I uploaded the urcap which shows custom dialog by using socket commucation in the other day.
In this time, the feature showing the dialog is implemented by XML-RPC daemon.
Why is it used JAVA for XMLRPC daemon?
It is possible to implement the keyboardInput feature of installation conribution on XMLRPC.
GITHUB LINK
Requirements:
URCaps SDK v.1.9.0
I hope this message finds you well. I wanted to reach out to you regarding your URCap for URsim-5.11.0.108249. I have installed the code perfectly on a virtual machine, and while the URCap appears to install correctly on the robot, it does not show anything. I was wondering if you might be able to offer any assistance or advice to help me troubleshoot this issue.
Thank you in advance for any help you can provide.
