# Problems in communication via profinet between Siemens ET200SP and UR16e 2
**URL:** <https://forum.universal-robots.com/t/problems-in-communication-via-profinet-between-siemens-et200sp-and-ur16e-2/28530>\
**Category:** Robot Communication\
**Created:** [May 22, 2023, 9:39am UTC](https://forum.universal-robots.com/t/problems-in-communication-via-profinet-between-siemens-et200sp-and-ur16e-2/28530 "2023-05-22T09:39:14Z")\
**Showing post:** 2
**Author:** ![anon964062](https://avatars.discourse-cdn.com/v4/letter/a/6f9a4e/32.png) [@anon964062](https://forum.universal-robots.com/u/anon964062)\
**Post date:** [May 25, 2023, 1:04pm UTC](https://forum.universal-robots.com/t/problems-in-communication-via-profinet-between-siemens-et200sp-and-ur16e-2/28530/2 "2023-05-25T13:04:10Z")
Hi Ugo,
I had the same issue and I just managed to solve it by updating the software version of my UR16e robot.
Generally, this error happens when there is a mistake in the setup for Profinet on the TIA portal. GSD file, and the network setup on the robot. First of all, make sure the GSD file that you are using matches the version of the robot software.
The IP, and Profinet device name assigned to the robot can also be the problem. Please make sure the IP you assigned to the robot is unique in your network.
The following are several links to discussions about this issue. They might be helpful.
> **["Device is not reachable" - 269953 - Industry Support Siemens](https://support.industry.siemens.com/forum/ie/en/posts/device-is-not-reachable/269953)**
> Hi nunobnk!I just received the same gateway (HD67719-IP-A1) and I'm really having trouble getting my S7-1516 to talk to it. The error I'm getting in TIA Portal is: "Device is not reachable" even though i can discover and it has an IP Add
> [@UR5e not reachable with profinet](https://forum.universal-robots.com/t/ur5e-not-reachable-with-profinet/19629):
> Hello! We have a problem with our URIOdev and modules that are not reachable. We have followed universal robots profinet guide and also some tutorials from this forum. [https://www.universal-robots.com/articles/ur/interface-communication/profinet-guide/](https://www.universal-robots.com/articles/ur/interface-communication/profinet-guide/)[[Universal Robots - Profinet Tutorial 1] ](https://www.youtube.com/watch?v=F6rHbVb6Y10)[[Universal Robots - Profinet Tutorial 2] ](https://www.youtube.com/watch?v=MhUDFoAdZNc) We are using siemens S7-1200 1211c firmware v4.4 TIA portal v16 The error messages that pops up is module not reachable.
_[View the full topic](https://forum.universal-robots.com/t/problems-in-communication-via-profinet-between-siemens-et200sp-and-ur16e-2/28530)._
