You can include script file in urp program. Look for script node.
Hi there. There is no function to convert a .script format directly into a .urp. The format of a .urp is xml. You can uncompress a .urp using WinRar. Open the resulting file format in an xml friendly editor and you will see the structure. Converting .script into .urp will take a lot of work on the part of the programmer.
