Universal Robots Forum
Daemon failed with real robot
My daemon have some problem with real robot but It working well with URSIM that excuted “sudo python daemon.py”
I attached error message as below:
XlmRPC port is correct.
What should I need to check more?
Thank you
org.apache.xmlrpc.XmlRpcException: Failed to read server’s response: Connection refused (Connection refused)
at org.apache.xmlrpc.client.XmlRpcStreamTransport.sendRequest(XmlRpcStreamTransport.java:161)
at org.apache.xmlrpc.client.XmlRpcHttpTransport.sendRequest(XmlRpcHttpTransport.java:143)
at org.apache.xmlrpc.client.XmlRpcSunHttpTransport.sendRequest(XmlRpcSunHttpTransport.java:69)
at org.apache.xmlrpc.client.XmlRpcClientWorker.execute(XmlRpcClientWorker.java:56)
at org.apache.xmlrpc.client.XmlRpcClient.execute(XmlRpcClient.java:167)
at org.apache.xmlrpc.client.XmlRpcClient.execute(XmlRpcClient.java:158)
at org.apache.xmlrpc.client.XmlRpcClient.execute(XmlRpcClient.java:147)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:226)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:684)
at java.awt.EventQueue.access$400(EventQueue.java:96)
at java.awt.EventQueue$2.run(EventQueue.java:645)
at java.awt.EventQueue$2.run(EventQueue.java:643)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:75)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:654)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:281)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:200)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:185)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:177)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:138)
Caused by: java.net.ConnectException: Connection refused (Connection refused)
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:327)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:193)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:180)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:384)
at java.net.Socket.connect(Socket.java:543)
at sun.net.NetworkClient.doConnect(NetworkClient.java:173)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:417)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:519)
at sun.net.www.http.HttpClient.(HttpClient.java:203)
at sun.net.www.http.HttpClient.New(HttpClient.java:296)
at sun.net.www.http.HttpClient.New(HttpClient.java:315)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:1004)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:940)
at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:858)
at sun.net.www.protocol.http.HttpURLConnection.getOutputStream(HttpURLConnection.java:1099)
at org.apache.xmlrpc.client.XmlRpcSunHttpTransport.writeRequest(XmlRpcSunHttpTransport.java:104)
at org.apache.xmlrpc.client.XmlRpcStreamTransport.sendRequest(XmlRpcStreamTransport.java:151)
… 24 more
