Universal Robots Forum
Daemon deploying
Hallo,
I tried to deploy My daemon like I did with the Hello World but i have always a problem and a fail message
is the My Daemon deployed the same way as Hello World or is there another way
NB: I did like it is mentioned on the SDK-Tutorial
thanks in advance
Did you ran it on the simulator or in the robot ?
I ran it On the Simulator
What command are you using to compile ?
Also, if you try to build it in the starter-pack virtual machine, you’ll have to remove some part of the pom.xml
Have a look at : Errors with HelloWorld and myDaemon (running the Starter Package)
