Universal Robots Forum
Active payload problem
Hey,
in initialization window my active payload is 0.1. after I press ‘START’ the active payload shows 0.23. If I press OFF, it changes again to be 0.87 (but not 0.1). this is dtrange. what could be my problem?
Thanks in advance
does this still happen after you generated a new installation?
Who could have influence on your payload -> URCaps, external connections etc.?
hey,
thanks for prompt reply.
I have created a new installation. it looks like I have two separate problems.
  1. the new installation solves me the problem that I described. However, after I have configured the RG2 gripper URCAP the problem appeared again.
  2. with new installation file (without gripper ) I have wrote a program. If I execute robot commands by MOVE HERE and then AUTO commands the arm works fine. however, if I push the play button with the same commands the robot goes to different xyz points. with constant deviation.
Thanks a lot
